  • Remi 3 posts 23 karma points
    Dec 12, 2014 @ 22:32
    Remi
    umbracoUrlAlias going crazy
    I have a small web site where i want to use custom url, hence using the umbracoUrlAlias property. The structure is as follow
    /www
        /en
            /home
            /products
    /content
        /product
            /productname
                /_en
                /_fr
    Inside the "/_en" node, i want to put this value in the umbracoUrlAlias property: "/en/product/productname"
    When i do so, i get a 404 error on the url "/en/product/productname"
    If i set the property to "/test/product/productname", it works like a charm. WHY!
    I did some umbDebug=true and found this that the SQL for serving /en/product/productname is :
    DECLARE @0 nvarchar(40) = N'6fbde604-4178-42ce-a10b-8a2600a2f07d',
            @1 nvarchar(4000) = N'productname';
    SELECT *
    FROM [cmsTemplate]
    INNER JOIN [umbracoNode]
    ON [cmsTemplate].[nodeId] = [umbracoNode].[id]
    WHERE ([umbracoNode].[nodeObjectType] = @0)
    AND ([cmsTemplate].[alias] = @1)
    which cannot work, the template under that document type is "locProduct"
    While the SQL for serving /test/product/productname is:
            @1 int = 1,
            @2 datetime = N'Dec 12 2014  2:12PM',
            @3 int = 1;
    SELECT *
    FROM [cmsDocument]
    INNER JOIN [cmsContentVersion]
    ON [cmsDocument].[versionId] = [cmsContentVersion].[VersionId]
    INNER JOIN [cmsContent]
    ON [cmsContentVersion].[ContentId] = [cmsContent].[nodeId]
    ON [cmsContent].[nodeId] = [umbracoNode].[id]
    AND ([cmsDocument].[published] = @1 AND [cmsDocument].[expireDate] <= @2)
    AND ([cmsDocument].[newest] = @3)
    ORDER BY [cmsContentVersion].[VersionDate] DESC
    , ([umbracoNode].[sortOrder])
    Anyone has an idea why this is happening?
    Dec 12, 2014 @ 23:53
    Remi
    More information:
    we are using version 7.2 of umbraco
    there is nothing in the umbraco log
    is there any tracing i could provide to help?
