  • Rune Grønkjær 1372 posts 3103 karma points
    Dec 18, 2014 @ 11:38
    Rune Grønkjær
    7.2 using the Grid system responsive
    Hi Guys,
    Have anyone created a responsive layout with the new grid system?
    The whole idea of the grid system i brilliant, but as I see it there's one big thing that it cannot do. We use Twitter Bootstrap 3 for our setups, and the grid system i that i brilliant. The fact that you can tell a column to be "col-md-4 col-sm-6" for example is great. But how would I do that with the Grid system in Umbraco 7.2?
    The default grid template renders the class like this: col-md-@area.grid
    This means I need to choose one size, in this case "md", and that cannot be changed.
    Don't we need the option to tell a column in the Umbraco Grid how to behave on all different sizes? Yes, I know there's other grid systems out there, so it would have to be a dynamic solution.
    /Rune
  • Robert Mulder 79 posts 272 karma points c-trib
    Jan 09, 2015 @ 20:52
    Robert Mulder
    I am wondering the same thing, have you found a way to work around this issue? Currently all I can think of is to add a custom property and change the way the display views work, but that seems like quite a bit of work...
    Jan 12, 2015 @ 08:20
    Rune Grønkjær
    @Robert - No, I have not figured this one out yet. I can't see this working without having to change a lot of markup on every new website. We will continue using Archtype to make stuff like this. http://our.umbraco.org/projects/backoffice-extensions/archetype/
    Unless someone comes up with a solution for the Grid system.
    /Rune
    Jan 12, 2015 @ 12:17
    Jeroen Breuer
    Did you try the Fanoe starter kit? It installs if you do a default install of Umbraco 7.2 without customizing.
    Jeroen
    Jan 12, 2015 @ 12:19
    Jan 12, 2015 @ 15:25
    Rune Grønkjær
    Hi Jeroen,
    Implementing and starting to use the grid system is not a problem at all. What they have done around that is fantastic, and very easy to use.
    The problem is making it truly responsive by alowing a block to fill 3 columns in one screen size and 4 columns in another. There's no settings for that, as far as I can see. All you can choose is one number of column per block and that won't cut it.
    /Rune
    Jan 12, 2015 @ 15:35
    Jeroen Breuer
    I understand the problem. Don't think there is a solution for that yet. Maybe you can do something with this blogpost: http://24days.in/umbraco/2014/grid-macros/
    You could also add a feature request here: http://issues.umbraco.org/dashboard#newissue=yes
    Jeroen
    Jan 12, 2015 @ 15:49
    Robert Mulder
    Well, what I decided to do is to just style each possible row configuration for responsiveness. We know that (for Bootstrap 3) the resulting html is similar to the following:
    div with attribute per row config property
      div.row
        div.col-md-xx.column
          div with attribute per column config property
    What I do is create a new row config property 'Row Template' that uses the dropdownlist as an editor with certain specific templates I plan on styling.
    Let's say one of the Row Templates is 'Unique Selling points' with value USP. The resulting html would become:
    <div row-template="usp">
      <div class="row">
        <div class="col-md-4>
           <div>some unique selling point</div>
    Now lets say I always want the USP's to be columns regardless of the width of the screen. I can simply add to my .less file:
    [row-template='usp'] {
      .col-md-4 {
        float: left;
        width: percentage(1/3);
    The biggest downfall of this approach is that the end user will always have to choose a row template in addition to picking a row configuration. It'd be much nicer if it were possible to add a default row class to a row configuration. This is really easy to add though (and it's what I do in practise as opposed to the template approach), but it requires modifying standard Umbraco files which I'm normally not particulary fond of...
