  • Lars Nederberg 29 posts 84 karma points
    Dec 19, 2014 @ 08:26
    Lars Nederberg
    Problem adding a group to a member in Umbraco 7.2
    Installed Umbraco 7.1 via Nuget and updated to 7.2 via Nuget
    Problem is that the selected group is not saved when saving the member.
    When i click a link representing a group under the properties tab for a member the group is moved to the right column "MEMBER OF GROUPS" as expected but when i save the member the group jumps back to the left column "NOT A MEMBER OF GROUP".
    Is this a known issue or is it me beeing a bad user?
    Dec 19, 2014 @ 08:30
    Hi Lars
    Have you been able to reproduce the issue on a fresh installation of 7.2?
    Dec 19, 2014 @ 08:43
    Lars Nederberg
    Hi Jan
    Just made a fresh install and could not reproduce.
    Could there be something wrong with my configs?
    Dec 19, 2014 @ 09:05
    Lars Nederberg
    Hi Jan
    Tried to remove  groups and add new. The new groups are working. Scary :)
    Dec 19, 2014 @ 22:40
    Hi Lars
    Ok, good that it works and that we now know it's not an issue in a fresh installation.
    Weird that it works all of the sudden - Did you change anything specifically on the fresh installation? Otherwise it might have been some cache?
