  • Ravi Motha 290 posts 500 karma points MVP 9x c-trib
    Dec 19, 2014 @ 10:42
    Ravi Motha
    Issue with ViewPage and Model in Umbraco 7.19
    I have a umbrcao 7.1.9 web site and I have form built using a view page with a model
    @using ww.ClientName.Logic.Model.Content;
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<Temp>
        Layout = "_layout.cshtml";
    @Html.Action("MyRegistration","RegisterSurface")
    The Model looks like this
     public class Temp : Base
            public Temp(int id)
                : base(id)
            [DataMember(IsRequired = true, Name = "Account Number")]
            [Display(Name = "Account Number")]
            [Required(ErrorMessage = "An Account Number is required")]
            //reg-ex
            public string AccountNumber { get; set; }
            [DataMember(IsRequired = true, Name = "Supply Address Postcode")]
            [Display(Name = "Supply Address Postcode")]
            [Required(ErrorMessage = "A Supply Address Postcode is required")]
            //postcode Regex
            public string Postcode { get; set; }
            [Display(Name = "Email address")]
            [Required(ErrorMessage = "The email address is required")]
            public string EmailAddress { get; set; }
    however when I switch @inherits Umbraco.Web.Mvc.UmbracoViewPage
    which is identical to Temp I get a
     public class RegistrationViewModel : Base
            public RegistrationViewModel(int id)
                : base(id)
            [Required(ErrorMessage = "The Account Number is required")]
            //reg-ex
            //postcode Regex
            //add validation for email address// datatype
    The model item passed into the dictionary is of type 'ww.Clientname.Logic.Model.Content.Temp', but this dictionary requires a model item of type 'ww.Clientname.Logic.Model.Content.RegistrationViewModel'.
    any help normally rewarded with hugs and love and sometimes beer.
    Ravi
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Dec 19, 2014 @ 14:21
    Dave Woestenborghs
    What kind of templatepage or umbracoviewpage do you use in your master layout ?
    Dave
    Dec 19, 2014 @ 14:31
    Ravi Motha
    I'm using this in my layout..
    @using ww.Clientname.Logic.Model.Content;
    @inherits UmbracoViewPage<Base>
    Dec 19, 2014 @ 14:37
    Dave Woestenborghs
    Can you inherit your layout from UmbracoTemplatePage ?
    Dec 19, 2014 @ 14:51
    Ravi Motha
    I've tried variations and that doesn't work as i don't pass the models I need to the pages..
    If it works with Temp, and registrationViewModel is exactly the same except for the name.. whya should one work and the other not..
    Dec 19, 2014 @ 14:54
    Dave Woestenborghs
    Your master layout is used by all pages. So the model can change for different pages. It is hard to tell without the whole picture
    Dave
    Dec 19, 2014 @ 15:11
    Ravi Motha
    Ii have a Umbraco View Page
        Layout = null;
        var member = Members.GetCurrentMember();
        var loggedIn = Model != null && Model.LoggedInCustomer != null;
    <!DOCTYPE html>
    <!--[if lt IE 9]>
        <html class="IE8" lang="en">
    <![endif]-->
    <!--[if gte IE 9]><!-->
        <html lang="en">
    <!--<![endif]-->
    <head>
        @Html.Partial("Properties",Model)
    </head>
        <body>
            <div class="wrap">
                @Html.Action("Header", "HeaderSurface", new {member})
            <div class="breakout">
                <div class="breakout-window">
                    <div class="breakout-content">
                        <h1>@Model.BreakoutTitle</h1>
                        <p>@Model.BreakoutText</p>
            <div class="wrap">
                  @if (!loggedIn)
                      @Html.Partial("MainMenu",Model)
            <div class="wrap row">
                <section>
                    @RenderBody()
                </section>
            <aside class="sidebar">
                <a href="#"><span>Live Chat</span></a>
            </aside>
                <footer class="footer">
                     @if (!loggedIn)
                         @Html.Action("Footer", "FooterSurface")
                    @Html.Partial("StaticFooter")
                </footer>
        </body>
    </html>
    I have a Base Document type and set a load of properties The only thing is the document type my register page inhrits from is called Temp.. because we had a bit of confusion there were a couple of registration document tyoes and I'm trying to kill the unnecessary pages and use a single layout template for reusability..
