I've been trying to set up an API Controller in Umbraco 7.2.1, but I'm having issues getting it to recognize the default routes.
This is my controller:
using System;
using System.Linq;
using System.Net;
using System.Net.Http;
using System.Net.Http.Headers;
using System.Web;
using System.Web.Http;
using Umbraco.Web.WebApi;
using MyProject.Models;
using MyProject.Models.Repositories;
namespace MyProject.Controllers.Api
public class BookingsController : UmbracoApiController
BookingsRepository repository;
public BookingsController()
repository = new BookingsRepository();
[HttpGet]
public HttpResponseMessage Index()
try
return Request.CreateResponse(HttpStatusCode.OK, repository.GetAllBookings(), "application/json");
catch (Exception e)
return Request.CreateResponse(HttpStatusCode.InternalServerError, (object)null, "application/json");
The problem is that neither the HTTP methods nor the action names can be implicitly resolved.
I expected to be able to reach the Index action by using "/umbraco/api/bookings" but it doesn't seem to be mapped.
If I try to call "/umbraco/api/bookings/index" it maps correctly but required me to explicitly annotate the action with [HttpGet] otherwise it will tell me GET is not allowed.
It does not look like a default action is mapped. See the source for how I think the routes are for the API. Not sure how you add your own routes since I have not had to use it yet. Interesting on the [HttpGet], I would find that a bit frustrating if that is the case.
Umbraco 7 API Controller - Default Routing Issue
Thanks in advance.
