Let's say I have a document type with alias BlogPost, which has properties:
BlogPost
When getting the latest 5 blogs contained in the site, I would use the following snippet:
var blogList = CurrentPage.AncestorOrSelf(1).Descendants("BlogPost").OrderBy("blogDate desc").Take(5);
However, I am trying to retrieve the latest 5 blogs where the date lies in a specific range (for example: after 15 December 2014).
I know that you can use the Where clause with a condition contained in a String, but I am attempting to compare two DateTimes:
Where
String
DateTime
Convert.ToDateTime("blogDate") >= new DateTime("15 Dec 2014")
Is this possible to do with a Where clause?
Yes, should be like this:
var blogList = CurrentPage.AncestorOrSelf(1).Descendants("BlogPost").Where("blogDate >= @0", new DateTime("15 Dec 2014")).OrderBy("blogDate desc").Take(5);
Great - tomorrow's question answered! :)
Tony
That's great Jeavon - thank you.
I made a mistake in my initial code: new DateTime("15 Dec 2014") should be new DateTime(2014, 12, 15)
Apart from that, Jeavon's code is perfect.
Getting descendants of node using where clause in razor
BlogPost, which has properties:When getting the latest 5 blogs contained in the site, I would use the following snippet:
Whereclause with a condition contained in aString, but I am attempting to compare twoDateTimes:Is this possible to do with a
Whereclause?Yes, should be like this:
Tony
new DateTime("15 Dec 2014")should benew DateTime(2014, 12, 15)Apart from that, Jeavon's code is perfect.
