So I guess you want to be able to display your content using different themes depending on the time of the year. If you plan to use the same HTML structure at all times it should be fairly easy. You don't want to keep multiple site sections where the theme is a part of the url since it's not good for SEO if you have multiple url's leading to the same content or you change the url's every 6 months...that will confuse the search engines and you need to setup 301 redirects etc. - I think it's the wrong path to go down at.
The way I see it what you need to do is to make sure you can change the path to the CSS files.
You can choose to do it manually evert time when you want to change the theme, or you could make a theme setting on your "Home" node where you setup a dropdown property editor in the "Developer -> Datatypes" where you add the names of your different themes (Could easily be more than two). Then add it to the "Home" document type in the "Settings" section.
Now you can choose and save the name of the theme.
You then need to create a macro that looks on the selected value and based on that decides, which stylesheet path should be used in your <link rel="stylesheet"> tag.
Thank you. I am genuinely enjoying my time exploring Umbraco, and this is a great community.
While what you suggested makes a lot of sense, I clearly presented a bad example, so I'll start over.
I would like to create a small site to cater for different group of people. Each group have their own skin and logo, but the exact same content, like so:
www.website.com/guitar/
www.website.com/guitar/meet-ups
www.website.com/guitar/music-events
www.website.com/violin/
www.website.com/violin/meet-ups
www.website.com/violin/music-events
Both /guitar/meet-ups and /violin/meet-ups presents exactly the same content, only different page skin.
I know I can set this by simply using URL querystring:
www.website.com/meet-ups/?group=guitar
www.website.com/meet-ups/?group=violin
The page template can then serves the appropriate CSS style according to [group] value.
I am just looking for an alternative to incorporate the [group] parameter as part of the URL.
I was thinking something along the lines of the following tree structure:
Happy to hear that you enjoy the community - Now you're a part of it yourself. Feels good, right? :)
When you say groups...is it then if people are logged in to the site using the "Members" section of Umbraco? If so it should be possible to check what group the current member is a part of and then serve the proper CSS file to them based on that knowledge.
That way you don't need to rely on the querystring either.
Ok, but if you don't control what you're serving to the different targets using Umbraco members how do you then plan to keep track on it?
You'll of course be able to persist the theme using a cookie or localstorage so users will see their preferred theme each time they visit the website - But you won't be able to know their preference beforehand.
But maybe it's just early in the morning and I'm misreading your post - Could it be that you just want a different theme pr. site section? So the guitar section looks different from the violin section?
In that case it should be a matter of making the same datatype as I suggested in my initial post and then just choose it on the parent nodes for the sections. So on the "Guitar" node you select the "Guitar" theme, which is then used on this node and the child-nodes and on the "Violin" page you choose the "Violin" theme, which is then displayed on the "Violin" page and it's children.
Just a quick suggestion,
If its same content, then can it the content be part of the template and set the theme at "www.website.com/violin/" and "www.website.com/Guiter/"?
@Jan / shinsuke : Thank you for the response, I apologise for the very late reply.
Tree structure suggested by both of you does make sense. However, I am trying to find solution which does not require the content editor to add another same tens of pages when a new [group] is introduced. Every instrument group has the same number of pages, with exactly the same content.
Example:
Home - Violin - Page A - Page B - ... (another 23 pages) - Guitar - Page A - Page B - ... (another 23 pages) - Keyboard (new group) - Page A - Page B - ... (another 23 pages)
After researching for awhile, I found another alternative which is a bit intriguing. Basically, I can use this tree structure:
Home - Page A - Page B - ... (another 23 pages)
Incorporate URL redirection rules like so: - IF user requests www.website.com/violin/meet-ups/, serve the content from www.website.com/meet-ups?group=violin. - IF user requests www.website.com/guitar/meet-ups/, serve the content from www.website.com/meet-ups?group=guitar.
The page template will check the querystring and render the correct layout as appropriate based on the group parameter. The user still sees www.website.com/violin/meet-ups/ format in their address bar.
I have created a file call "app_start/RouteConfig.cs"
namespace Umbraco.Extensions.EventHandlers
public class MyStartupHandler : IApplicationEventHandler
public void OnApplicationInitialized(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
public void OnApplicationStarting(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
public void OnApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
//Create a custom route
RouteTable.Routes.MapRoute(
"test",
"products/{id}/{action}/{controller}",
new
controller = "Test",
action = "Test",
id = UrlParameter.Optional
In the routing rule, i setup
in this url structure, i put it under "products" url because the system needs to distinguish between umbraco routing rule vs your own routing rule. so anything under "http://url.com/products/" will be using your routing rule. Else it will be using Umbraco Rule.
Then i have "{id}/{action}/{controller}" instead of {controller}/{action}/{id} because i want to have following url structure
I really don't like how i had to change the routing rule to "{id}/{action}/{controller" but thats the only way i can think of without creating many controllers for different groups.
Let me know if you found better solution, i'm curiouse as well :)
Setting up multi-section website sharing the same page sets
Hi all,
First time on the forum, please let me know if I am not posting this in the right category.
I am hoping I can get some ideas on setting up the correct CMS structure.
I want to build a relatively small site with simple content, like so:
I know I can simply set up the tree like so:
However, I want to be able to customise the colour and logo by introducing identifier in the URL, like this:
I can set up the tree like so:
However, this is not very efficient, as the core content for /about-me and /about-you are always the same.
What would be the best approach to achieve this?
Thank you,
Johan.
Hi Johan and welcome to our :)
<link rel="stylesheet">tag.Does this make sense?
Hi Jan,
Thank you.
Hi Johan
Looking forward to hearing from you.
Hi Jan,
It does. Awesome indeed.
I will not be using the Members login feature by Umbraco, Jan.
I want to make it as simple as possible and my target audience / public with URL can access it at anytime.
Thanks, Johan.
Hi Johan
Hope this is what you have in mind? :)
Hi guys,
Just a quick suggestion, If its same content, then can it the content be part of the template and set the theme at "www.website.com/violin/" and "www.website.com/Guiter/"?
so page structure look like this
and the content can be hard coded in the template?
or you can create partial view or macro
Yup, that's exactly what I meant in my previous response :) But thanks for making it visually clearer #h5yr
arhh ops, sorry Jan :) i wanted emphasis more in hard coding content in template / partial view. Tho i strongly don't encourage any hard coding.
Also Welcome Johan, good to see another developer from Australia :)
@shinuske - No need to be sorry - Your answer is clearer since it visually is quicker to grasp the concept than my long writing ;-)
Example:
Home
- Violin
- Page A
- Page B
- Guitar
- Page A
- Page B
- Page A
- Page B
Home
- Page A
- Page B
Can I get your opinion on this, please?
Thank you,
Johan.
Hi Johan,
hmm weird, i can't see your post, i can only see via email. or change the url manually.
If you don't want to create page by page, right now i can think of 2 ways:
With Option 2, you have to create your own routing rule.
I just created prototype base on your scenario and it seems to work.
the reference i used to build my prototype can be found here ref: http://shazwazza.com/post/Custom-MVC-routing-in-Umbraco
and in your TestController it will look something like this:
Then you can have following URL structure without creating many trees / pages
cheers
Shinsuke
