On a v 7.1.1 site we had a bit of trouble with editing nodes - or rather save and publish newly edited content after already saving and publishing. It did save and publish the first time, but the button stayed grayed out so if we edited more, we couldn't save.
I then upgraded to 7.2.1 to see if it had been solved, but it hasn't. However, I did some more digging and it turns out that it only does this when we try to embed macros in the Richtext field. Specifically macros with parameters. Looks like it's only with parameters of types Media Picker and Content picker - textbox doesn't do this.
It seems to be due to a javascript error - it says "MacroData is null". However, the macros work fine and nothing seems to be missing.
V7.1.1/v7.2.1: Odd behaviour on embedding macro with parameters
Can anyone help resolve this?
Kind regards, Bruno
Hi Bruno
Sounds like it's a bug - Have you tried to report it on the issue tracker perhaps?
Hi Jan
I'll try that :)
/Bruno
