I am currently in the process of building an Ajax-driven payment system within Umbraco and I am currently trying to load a partial view containing an Umbraco form using @Ajax.Action.
This is for Umbraco v6. The tutorial I found online was also for this older version of Umbraco but I am using the most recent version which it did not seem to work with.
Jason Espin, did you ever manage to solve this? Curiously, five years later, I am exactly in the same spot, but with Umbraco 8. As far as also getting the "Length" attribute after the route.
Using Ajax.ActionLink with a Surface Controller
Hi all,
My problem is that with the following settings:
The button generated resolves to the following Url:
How do I ensure that this correctly resolves to my SurfaceController?
Maybe this post can help you. I followed this and got it working :
http://www.systenics.com/blog/creating-an-ajax-enabled-contact-form-in-umbraco-6-with-aspnet-mvc-4-and-twitter-bootstrap/?tag=Umbraco+6
Dave
Hi Dave,
Jason
Hi Jason,
Using surface controllers in v6 and v7 should work the same.
Can you post some code ?
Dave
I have posted the code above. It is the same as what you sent over in the link except it always fails to direct to
and instead routes to
I also have no idea where the Length=15 is coming from as I do not specify that anywhere
We have this in our view :
@{ HtmlHelper.ClientValidationEnabled = true; HtmlHelper.UnobtrusiveJavaScriptEnabled = true; var ajaxOptions = new AjaxOptions { HttpMethod = "POST", InsertionMode = InsertionMode.Replace, UpdateTargetId = "commentForm" }; } <section > <div > <header> <h1>@Model.InnerModel.CommentFormTitle</h1> </header> @using (Ajax.BeginForm("SubmitMessage", "CommentsSurface", ajaxOptions, new { @id = "commentForm" })) { <div > <div > <p> @Html.TextBoxFor(m => m.CommentModel.Name, null, new { @placeholder = Model.InnerModel.CommentFormNamePlaceholder }) @Html.ValidationMessageFor(m => m.CommentModel.Name) </p> <p> @Html.TextBoxFor(m => m.CommentModel.Email, null, new { @placeholder = Model.InnerModel.CommentFormEmailPlaceholder }) @Html.ValidationMessageFor(m => m.CommentModel.Email) </p> <p> @Html.TextAreaFor(m => m.CommentModel.Message, new { @placeholder = Model.InnerModel.CommentFormMessagePlaceholder, @cols = "40", @rows = "10" }) @Html.ValidationMessageFor(m => m.CommentModel.Message) </p> </div> <div > <p> <input type="submit" value="@Model.InnerModel.CommentFormButtonLabel"> </p> </div> </div> <input id="commentSubmitBtn" type="hidden" value="@Model.InnerModel.Id" name="modelId"/> <input id="lcid" type="hidden" value="@System.Threading.Thread.CurrentThread.CurrentCulture.LCID" name="lcId"/> } </div> </section>Maybe this can help.
Dave
This still does not work for me and fails to direct to the Surface Controller correctly.
Can you post all your code ? Controller..view ... etc..
Dave
