Grid editor configuration issue, applying div class
Hi all,
I'm wondering if someone can point me in the right direction. I'm trying to edit the Headline control in the grid.editors.config.js file - it would seem when I add a div class I get a null reference exception. From looking at the Umbraco documentation I should be able to do this. Any help is greatly appreciated.
Happy to see you got it fixed by recycling the app pool. Each time a change is made to the files in the /config/ folder this is necessary - So keep that in mind next time something does not work as expected after modifying any of those files :)
And please mark the post as solved so others can go straight to the solution if they encounter the same issue.
Hi all,
Hi Ryan
What does the error message look like? Do get any additional information?
Have you recycled the app pool after making the change? And is the "debug" attribute in the web.config set to "true"?
Looking forward to hearing from you.
Hi there,
I recycled the app pool and now everything seems to be working fine. I couldn't work out why it was throwing a null reference exception - so annoying.
Thanks for the help.
Hi Ryan
Cheers, Jan
ooops I solved the wrong post. Could you remove it and I'll mark your post as the solution
Hi Ryan
Currently that's not possible - But it will be in the upcoming version of the forum. But there is no release date yet :)
