  • Jordy Vialoux 73 posts 103 karma points
    Jan 23, 2015 @ 23:22
    Jordy Vialoux
    Umbraco 7 | If checkbox "checked" add class to body
    Hi Guys,
    I'm new to razor but not Umbraco and I'm wanting to know how to add a class to the body element if the user "checks" a checkbox within the generic properties tab.
    I understand this is simple but unsure on the code to append to the body tag.
    Jan 24, 2015 @ 06:25
    Hi Jordy
    You should be able to achieve this by using the ternary operator something like this
    <div class="@(CurrentPage.myProperty != String.Empty ? "myStyleOne" : null)">
    This should only add the class if your property is not empty otherwise the class will be empty.
    Hope this hels (and works) :)
