  • Flavio Spezi 129 posts 315 karma points
    Jan 28, 2015 @ 00:24
    Flavio Spezi
    Inherited Tab sort order is not replicated after changed - Temporary patch
    I found an issue in Umbraco 7.2.0 - 7.2.1.
    The Tab sort order value is not replicated to inherited document types after it is changed.
    The issue is discussed here: http://issues.umbraco.org/issue/U4-6195
    I found a temporary patch to this.
    When you look some wrong order of tabbs, you can adjust this executing this T-SQL code to the database.
    Careful: to avoid loss of data make a backup of database before to proceed.
    UPDATE TB1
    SET sortorder = TB2.sortorder
    FROM [cmsPropertyTypeGroup] TB1
        INNER JOIN [cmsPropertyTypeGroup] TB2 ON TB1.parentGroupId = TB2.id
    WHERE TB1.sortorder <> TB2.sortorder
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Jan 28, 2015 @ 12:14
    Jeroen Breuer
    Thanks for the tip. I'm still having this problem sometimes.
    Jeroen
  • Markus Johansson 1945 posts 5899 karma points MVP 3x c-trib
    Sep 05, 2015 @ 14:20
    Markus Johansson
    Worked for me! Thanks for sharing the SQL =D
    Sep 05, 2015 @ 14:42
    Flavio Spezi
    You are welcome.
    I am happy to help the community
