  • Faisal Mushtaq 19 posts 119 karma points
    Feb 02, 2015 @ 14:05
    Faisal Mushtaq
    Scheduled publish and unpublish problem.
    I am doing scheduled publish/unpublish functionality using "Publish at" and "Unpublish at". But when I set time then functionality works fine but after one or two minutes difference. Please let me know is it umbraco default behaviour? or I have to do other configution stuff to overcome this problem.
    Feb 02, 2015 @ 14:47
    Hi Faisal
    What version of Umbraco are you using? This function has had a history of working / not working bewteen releases.
    However I suspect that it may be a time difference on your computer and the server, which is causing the issue perhaps? Are both machines in sync time-wise?
    Feb 02, 2015 @ 15:23
    Faisal Mushtaq
    Hi Jan,
    We are using umbraco 7.2. And we are testing this functionality on same machine where deployed.
    Faisal.
    Feb 02, 2015 @ 17:11
    Hi Faisal
    Ok, then it might be worth adding a detailed issue description on the issue tracker :) - Should be happening at the correct time - Not sure what could cause the delay.
    Feb 03, 2015 @ 07:11
    Faisal Mushtaq
    Issue created with bug id U4-6227.
    Faisal.
