  • James 251 posts 1169 karma points
    Feb 07, 2015 @ 19:44
    James
    Using Umbraco on freelance projects/ websites
    Hi all,
    I currently have a freelance site set up. I do work for a couple of clients and sell Umbraco sites to them.
    Can i advertise on my site that i use Umbraco? What are the rules with regards to using the Umbraco logo?
    Sorry if this is mentioned somewhere else.
    Kind regards,
    J
    Feb 07, 2015 @ 21:33
    Hi James
    I don't recall that there are any certain rules about using the logo - However using the Umbraco name in a domain name for instance is a no go. But if you're doing solutions based on Umbraco you should be allowed to use the logo for promoting your services etc. as long as it's relevant and all that jazz.
    I'm certain that someone will correct me if I suffer from bad memory :)
    Otherwise it might be a good idea to ask the same question on Twitter using the #umbraco hashtag to feel the vibes. But I don't think it's an issue at all when you're doing Umbraco work.
