  • Brian 77 posts 251 karma points
    Feb 11, 2015 @ 17:13
    Brian
    Reference a true / false in XSLT
    Hi guys,
    I am trying to reference a true false datatype called 'pickOfTheWeek' in xslt and then display referenced info (see code below).  Unfortunately I cannot seem to get this to work.
    Here is the snippet code I am trying to select pickOfTheWeek:
    <xsl:if test="string(./pickOfTheWeek) = '1'">
    and here is the full code:
    <!DOCTYPE xsl:stylesheet [<!ENTITY nbsp "&#x00A0;">]>
    <xsl:stylesheet  version="1.0"
      <xsl:template match="featuredImage">
    <img src="{.}"  />
    </xsl:template>
      <xsl:template match="/">
      <xsl:variable name="excerptLength">
        <xsl:choose>
          <xsl:when test="string(/macro/excerptLength) != ''">
            <xsl:value-of select="/macro/excerptLength"/>
          </xsl:when>
          <xsl:otherwise>500</xsl:otherwise>
        </xsl:choose>
      </xsl:variable>
     <xsl:variable name="numberOfItems">
        <xsl:choose>
          <xsl:when test="/macro/numberOfItems != ''">
            <xsl:value-of select="/macro/numberOfItems"/>
          </xsl:when>
          <xsl:otherwise>2</xsl:otherwise>
        </xsl:choose>
      </xsl:variable>
        <xsl:variable name="recordsPerPage" select="1"/>
        <xsl:variable name="pageNumber">
          <xsl:choose>
            <xsl:when test="umbraco.library:RequestQueryString('page') &lt;= 1 or string(umbraco.library:RequestQueryString('page')) = '' or string(umbraco.library:RequestQueryString('page')) = 'NaN'">1</xsl:when>
            <xsl:otherwise>
              <xsl:value-of select="umbraco.library:RequestQueryString('page')"/>
            </xsl:otherwise>
          </xsl:choose>
        </xsl:variable>
     <xsl:for-each select="$currentPage/TheDscTeam/* [@isDoc and (umbracoNavihide)= '1']">
      <xsl:sort select="@createDate" order="descending" />
    <div class="column">
    <div class="colcontainer">
    <figure><a href="{umbraco.library:NiceUrl(@id)}"><xsl:apply-templates select="ancestor-or-self::*[normalize-space(featuredImage)][1]/featuredImage" /></a></figure>
    <h4><xsl:value-of select="@nodeName"/></h4>
    </div><!--colcontainer-->
    <p>
      <xsl:choose>
                    <xsl:when test="string($excerptLength) != '0'">
                      <xsl:value-of select="umbraco.library:TruncateString(umbraco.library:StripHtml(mainContent), number($excerptLength), '...')" disable-output-escaping="yes"/>
                    </xsl:when>
                    <xsl:otherwise>
                      <xsl:value-of select="mainContent" disable-output-escaping="yes"/>
                    </xsl:otherwise>
                  </xsl:choose>
      </p>
    <a href="{umbraco.library:NiceUrl(@id)}" class="readfull">Read Full Article</a>
    </div><!--column-->
    </xsl:if>
          </xsl:for-each>
      </xsl:template>
    </xsl:stylesheet>
    I know XSLT is frowned on these days but alas it is all I am familiar with at present.
    Feb 11, 2015 @ 21:56
    Hi Brian
    Nothing wrong with using XSLT :)
    From the above code I'm a bit unsure if the context is right though...Where does the pickOfTheWeek property exist? Is it on the TheDscTeam document type or is it on a child type?
    And are you certain the it's either 1 or 0 that is returned? If so try removing the single quotes that '1' is wrapped within.
