In this video, Tim is just adding a controller in the controllers folder without any problems. Am I the only one where the “add controller” is greyed out in Visual Studio 2013?
Hmm, coming to think of it - have you right clicked the "controllers" folder and chosen to "include" it in your project? If not then try doing it and see if that works?
Surface controller / add controller VS 2013
I have installed Umbraco with NuGet following this guide:
https://our.umbraco.org/documentation/installation/install-umbraco-with-nuget
I am now following UmbracoTV videos about surface controllers and I am stuck with this video:
http://umbraco.tv/videos/developer/fundamentals/surface-controllers/the-surface-controller/
// René
Hi René,
are you perhaps in debug mode? If so, then click on stop and check if it works now.
Best,
Sören
Hi René
Sören - I am not in debug mode, so thats is not the problem.
Jan - The folder is included in the project.
Maybe it is done in a different way in VS 2013? Should i use "add new item" which gives me a lot of different choices?
// René
Hi René,
a surface controller is a class. If you can use "add new item" you can do this and choose "class".
Best,
Sören
Hi Sören
Could it be "Web API Controller Class (v2.1) or (v1)?
// René
Hi René,
can you choose "MVC 4-Controllerclass" or a simple "Class". It should be possible to choose a simple "Class" and use this.
Best,
Sören
Hi Sören
I can choose:
Visual C# -----> Code -----> Class (An empty class declaration).
It creates a file like this "file.cs" with this default code:
Would that be the correct one?
// René
Hi René,
yes :-) And now you must inherit your class from Umbraco.Web.Mvc.SurfaceController like this:
This is your first SurfaceController.
Best,
Sören
Hi Sören
That's perfect. Thanks!
// René
