After publishing content my Examine results are often missing content.
I need to go into Examine Management and rebuild the ExternalIndexer index for search results to include all nodes correctly.
Is there a way to do this automatically? Or can I set a rebuild interval?
I notice there's an interval attribute I can add in the config file, but I can't find any docs describing what this does.
Thanks in advance,
David.
Hi David,
You can try to call rebuild examine indexes after publishing your content via events.
https://our.umbraco.org/documentation/Reference/Events-v6/ContentService-Events
Ok, thanks Alex. Is there nothing out of the box?
Do you know when the index is rebuilt by default?
Thanks again.
here is the examine documentation:
https://our.umbraco.org/documentation/reference/searching/examine/
In the "Full configuration markup example" you can find an example for the interval attribute.
Best,
Sören
Thanks Sören, Examine makes much more sense now.
Great overview here: Overview & Explanation - "Examining Examine by Peter Gregory"
glad that I could help you :)
Upload image
Examine Index
Thanks in advance,
David.
Hi David,
Thanks again.
Hi David,
Best,
Sören
Hi David,
