It shows what I expect, but because it defaults to my home page Node.Id instead of the 1245 Node.Id, the formatting is all messed up. This is for Umbraco 7.1.8.
You have setup the 404 page with the nodeid of 1245...but when you hit a page that does not exist you see the frontpage instead? And how is the styling messed up? Could you share a screendump?
It's actually failing on sitemap, which is a variation of a known and vialable page, site-map, and just happens to be the 404 page we want to use. It's doing is the proper content, but not the proper format because I have it checking for the node.id to determine the body class and since it's returning the node id of the home page instead of the site mape, it's setting the body class as front instead of secondary.
Unfortunately, I can't do a screen dump because the site is still in development.
Content type is Content. Template is Sitemap, which is the Sitemap.cshtml file under the views directory.
What is interesting is I can put the same url of /sitemap in a Umbraco 6 site and it doesn't have the problem. It goes to the site-map page like it's supposed to with the proper formatting and proper node.Id.
404 Showing Right Content, Identifying itself as wrong node
I have followed this:
https://our.umbraco.org/wiki/install-and-setup/configuring-404-pages, even doing the part httpErrors Passthrough and setting the "trySkipIisCustomErrors" to true. My error configuration is like this:
Upgrading to 7.2.1 didn't help
Hi there
Hmm, I'm not sure I get what is happening.
What server are you using? Is it IIS 7 or 8 8 or?
IIS7.5.
Ok
So it's actually working but it's due to the wrong class name being set.
Is the sitemap based on an alternative template? Or is it based on a custom document type called "Sitemap" ?
