  • AmandaEly 123 posts 379 karma points
    Mar 17, 2015 @ 09:33
    AmandaEly
    Unable to build fresh copy of Hybrid Framework
    Hi, I downloaded the zip version of this project from https://github.com/jbreuer/Hybrid-Framework-for-Umbraco-v7-Best-Practises this morning and opened it in my copy of Visual Studio 2013. I'm afraid it won't build right out of the box. The error seems trivial but I don't want to go messing with it. The problem seems to be in File.generated.cs enter image description here
  • schlubadub 102 posts 617 karma points
    Mar 17, 2015 @ 10:25
    schlubadub
    Look at the last error - your file path is too long "C:\Websites\UmbracoSites\Hybrid-Framework-for-Umbraco-v7-Best-Practises-master\Hybrid-Framework-for-Umbraco-v7-Best-Practises-master"
    Try renaming the two "Hybrid-Framework-for-Umbraco-v7-Best-Practises-master" directories to "Hybrid-Framework" instead. You may have to unzip there in the first place if it still doesn't work (as some packages fail to install properly when the path is too long)
    Mar 17, 2015 @ 10:44
    AmandaEly
    That's it. Thank you.
