I'm guessing I avoid using the @Model.Content.GetGridHtml("propertyname) method and manipulate it by getting the JSON string Model.Content.GetPropertyValue("propertyname")?
Hi Jeroen thanks for your reply. I've managed to get the Media id and have the focal point positions how would I use imageprocessor combine them to crop the image to as size to which either is closest (width/height) and in relation to focal point?
in the grid.editors.config.js file you can add different image configurations and that allows editors to pick which image size they want for the correct purpose. The media.cshtml render page is looking for a config object with a size in. You can define this config in the grid.editors.config.js file.
Thanks for the reply, it has really helped... I was wondering if you could share a quick example on how to use media.cshtml file to render a crop alias?
Just tried adding a package.manifest as your example and don't see anything appearing anywhere in the grid settings panes or when adding an image, or in the dataType. I've read the docs, think I've satisfied all requirements and don't have any syntax errors. Where should I see whatever it is you see to effect the size change?
How to crop images within Grid Layout
Hi, does anyone have any thoughts on how you could use the image processor within the grid layout?
Looking at the View/Partials/Grid/Editors it appears like there could be an option?
My only way around this would be to create different Editors for each image size variation.
After selecting an image with the media picker on the grid you can crop the selected image. Is that what you want?
Jeroen
Hi Jeroen do you have a screen shot of what you mean?
Thank you
1. Choose the image option on the grid.
2. You can select an image with the media picker.
3. After selecting the image you choose a focal point for the crop.
Jeroen
My attempt so far is
?anchor=@control.value.focalPoint.left,0,@control.value.focalPoint.top,0&cropmode=percentage&width=350&height=179
Or you could change the media.cshtml render file to look for a crop alias.
Hi Simon Kerr,
Hi Harnam, you shouldn't use grid.editors.config but instead make your customized editors in a package manifest as per the documentation.
When the size is defined it will automatically be rendered using just using the normal media.cshtml.
I put this in
/App_Plugins/Grid/package.manifest(You can name the sub folder whatever you want)and this is then rendred on the page
<img src="/media/1002/late.jpg?width=200&height=200&center=0.29,0.740088105726872&mode=crop">Happy New Year :)
Rune
Hi Rune,
Thanks.
