  • Donatello 5 posts 44 karma points
    Mar 18, 2015 @ 15:35
    Donatello
    Use a different connection string
    We're trying to have Umbraco use a connection string we pass it from the code. Reason being, we get the connection string from outside of the web.config and we can't change this constraint.
    Is it possible to do this? We are not allowed to modify the web.config from the source code as well so editing it from the code to add the UmbracoDbDSN parameter is not an option...
  • Alex Skrypnyk 6179 posts 24240 karma points MVP 8x admin c-trib
    Mar 18, 2015 @ 16:44
    Alex Skrypnyk
    Hi Donatello,
    Welcome to our community,
    Try to look at this code :
    Configuration config = ConfigurationManager.OpenExeConfiguration(ConfigurationUserLevel.None);
    config.AppSettings.Settings["umbracoDbDSN"].Value = “New Connection String”;
    config.Save(ConfigurationSaveMode.Modified, true);
    ConfigurationManager.RefreshSection("appSettings");
    Thanks, Alex
    Mar 18, 2015 @ 16:57
    Donatello
    Hi Alex
    thanks a lot for your help.
    We've tried and used this successfuly but we are unfortunately not allowed to modified the web.config file anymore...so this solution couldn't work for us.
    Mar 18, 2015 @ 17:07
    Mar 18, 2015 @ 19:30
    Donatello
    Spent some time testing this solution as well but whichever way I try to access the configuration it is read only (ApplicationContext.DatabaseContext.Database.Connection.ConnectionString is readonly)
    What I was hoping for was a way to hook up in the Umbraco database layer initialization and being able to "inject" a different connection string. But looking at the Umbraco source code, it doesn't seem to be feasable...any suggestion would be appreciated.
  • NAGENDRA 2 posts 71 karma points
    Feb 11, 2020 @ 21:08
    NAGENDRA
    Hi Donatello,
    just want check with you, did you find any way to resolve your issue. I'm also facing the same issue.
    Thanks, Nagendra
