  • Jon Frederiksen 52 posts 111 karma points
    Mar 21, 2015 @ 09:30
    Jon Frederiksen
    U 7.2.4 media picker problem
    I've updated this morning a small website from v.7.2.2 to 7.2.4 and everything seems to work fine, except the media picker. When used from the rich text editor to insert image, the right side media dialog shows, but nothing else, no folder or image. It just keeps loading and cancelling won't do anything. The select button also shows the angular value, as in the attached image.
    I've tested on a fresh 7.2.4 installation and there is no such error, so I'm sure is related to the upgrade from 7.2.2 to 7.2.4.
    It's a small website, running on SQL CE. For upgrading I've followed the general upgarde guide and copied bin, Umbraco and Umbraco_Client.
    Any help or hints apreciated.
    Mar 21, 2015 @ 09:37
    Dennis Aaen
    Hi Jan,
    After you have copied bin, Umbraco and Umbraco_Client, then make sure to clear the browser cache and try increment the clientdependency version in the /Config/ClientDependency.config
    Hope this helps,
    /Dennis
    Mar 21, 2015 @ 10:43
    Jon Frederiksen
    Hi Dennis
    Thank you for that. Of course it helped!
    I don't beleive I forgot to check the ever annoying cache, which in Chrome is the worst.
