  • Melanie Rohr 7 posts 28 karma points
    Mar 24, 2015 @ 23:11
    Melanie Rohr
    Multi Url Picker throwing null reference exception
    I'm trying to use this Multi Url Picker but can't seem to get it to work. I've installed the package from the repository and followed the example code but get a System.NullReferenceException: Object reference not set to an instance of an object. Using Umbraco 7.1.8.
    Any ideas?
  • Valerie 67 posts 163 karma points
    Mar 25, 2015 @ 11:57
    Valerie
    Can you paste the code you are using? Which line does the null reference happen on? Does it blow up before you have retrieved any items?
    I'm using it in 7.1.8 and it's fine. Here's a gist of my code
    https://gist.github.com/anonymous/fe8f03f1a9ade0bc2b9d
    Apr 01, 2015 @ 20:27
    Melanie Rohr
    I'm using the razor code example from the projects page like so:
    @using RJP.MultiUrlPicker.Models
    @{ var multiUrlPicker = Model.Content.GetPropertyValue<MultiUrls>("myPropertyAlias"); if (multiUrlPicker.Any()) { <ul> @foreach (var item in multiUrlPicker) { <li><a href="@item.Url" target="@item.Target">@item.Name</a></li> } </ul> } }
    Apr 02, 2015 @ 21:40
    Melanie Rohr
    Finally figured it out! Totally my bad!The code was nested in an if statement and I had totally referenced it wrong :(
