  • Anne Uth 23 posts 43 karma points
    Mar 26, 2015 @ 10:51
    Anne Uth
    Imagesize bigger with imagecropper than without
    I have an umbraco 7 website where i use the imagecropper to give image in different sizes depending on which device you use.
    On desktop the crop is 1440*710
    I have uploaded an image that is optimised for web for the imagesize is 160KB and 1440*710.
    But if i use the cropper to get the image the imagesize is twice as big. 329KB
    Does anybody know why this is?
  • Jeavon Leopold 3074 posts 13632 karma points MVP 12x admin c-trib
    Mar 26, 2015 @ 11:02
    Jeavon Leopold
    Hi Anne,
    As you are cropping the image it is being recreated. Do you have a quality variable on your url (I think it got slightly cut off)?
    Jeavon
    Mar 26, 2015 @ 11:06
    Anne Uth
    No i don't have that. How do i do that?
    Mar 26, 2015 @ 11:07
    Jeavon Leopold
    Could you post your code with the GetCropUrl method?
    Mar 26, 2015 @ 11:09
    Anne Uth
    Yes, I do like this:
    var media = helper.TypedMedia(Id);
    media .GetCropUrl("Desktop");
    Mar 26, 2015 @ 11:16
    Jeavon Leopold
    Great, so you should be able to do this:
    media.GetCropUrl(cropAlias: "Desktop", furtherOptions: "&quality=80");
    Mar 26, 2015 @ 11:20
    Anne Uth
    Thanks. Now it is 263KB so it helped. Do you know where i kan find a description of what i can put in "furtherOptions"?
    Mar 26, 2015 @ 11:23
    Jeavon Leopold
    Yes, you can use any method listed on the ImageProcessor.Web documentation here
    Mar 26, 2015 @ 14:58
    Anne Uth
    When i use quality as a parameter the width and height disappears from the url
    before
    /media/1594/forsideannonce-ny-pro.jpg?anchor=center&mode=crop&width=1440&height=710&rnd=130711490020000000
    After
    media/1594/forsideannonce-ny-pro.jpg?anchor=center&mode=crop&quality=60&rnd=130718462820000000
    Now the image is not cropped in the correct size. How do i get the width and height back?
    Mar 26, 2015 @ 16:41
    Jeavon Leopold
    Ah try this:
    media.GetCropUrl(cropAlias: "Desktop", useCropDimensions:true, furtherOptions: "&quality=80");
