  • Anne Uth 23 posts 43 karma points
    Mar 26, 2015 @ 14:08
    Anne Uth
    Multi node picker - no visible path when hover
    Im using umbraco 7.2.1 (an upgrade from umbraco 6). The customer asked why the path on hover in multi node tree picker is gone, and if he can get it back? I umbraco 6, you could hover the items in the picker and get the path to where the node is in content section.
    Mar 26, 2015 @ 15:26
    Hi Anne
    I think it's because the Multi node picker has been rewritten and this is an oversight from HQ perhaps. Originally the MNTP was developed as a part of uComponents that got merged into the core...so whoever rewrote the code has perhaps not been aware of this nice little thing.
    I think that you should file an issue about it on the issue tracker so it can make it's way into the core.
    Meanwhile I think you should be able to find the relevant file and add a title somewhere, which will display the path if you feel like it :)
    Mar 26, 2015 @ 15:37
    Anne Uth
    Do you know where i can find that file and how to get title?
    Mar 26, 2015 @ 15:50
    Hi Anne
    I don't know the code base that well but you should be able to search in the source code here to get an idea https://github.com/umbraco/Umbraco-CMS/search?utf8=%E2%9C%93&q=multi+node+picker - I just searched for "multi node picker" - Perhaps searching for "multinodepicker" or "multinodetreepicker" will give you some more accurate results - I suspect that the "multinodetreepicker" might be legacy though since it seems to be written in C# and I'm confident that the new one should be all angularjs based.
    Hope this is enough to get you going :)
