Which is the better method to project and build a web application and consume services with Umbraco?
I need to build a web application where I wish to use Umbraco as frontend and backend control panel to push info to a mobile app. My idea is to build an MVC project with my WebAPI and use them from Umbraco? Is't the right direction?
- How is possible to pass authentication token to webAPI? Because I wish to use Umbraco auth.
- Which is the better solution to create a big solution under VS with: one project for Umbraco, one for WebApi and one for a MVC project for a custom control panel?
Hi Biagio
Judging from your short description the approach you mention sounds right - Perhaps you can also find some inspiration from these pages
http://www.umobileapp.com/
http://www.sumac.uk.com/blog/production/managing-mobile-applications-with-umbraco/
http://slid.es/johnw86/apps-with-umbraco
http://www.prodo.com/blog/phonegap-and-umbraco/
http://stream.umbraco.org/video/9946228/going-native-with-umbraco-and-phonegap
http://24days.in/umbraco/2014/architectural-thoughts/
I hope this helps a bit.
Thank you.
Other questions.
