  • Robert J. Bullock 386 posts 405 karma points
    Apr 20, 2015 @ 16:59
    Robert J. Bullock
    Umbraco 6 to 7: Multi Node Tree Picker Conversion
    Ok, I upgraded my site from 6 to 7. It's going fairly well now after fixing a lot of show stoppers! However, I just found out that MNTP didn't convert properly. In the old site, we stored the data as XML. In U7, it's stored as JSON (or looks like CSV to me, whatever)...
    The problem is how do I take the existing XML data and convert it to the new format? The data is not available via Umbraco even because U6 stored the XML in the dataNText field and U7 stores it in the dataNVarchar field in the cmsPropertyData table.
    Apr 20, 2015 @ 17:11
    Jeroen Breuer
    I had the same problem. It was faster for me to manually change all the content than writing a converter. You could have a look PhoenixConverters.
    Jeroen
    Apr 20, 2015 @ 17:33
    Robert J. Bullock
    Yeah, it just might be... Only talking about 25-30 nodes. I guess I can just do it in the database manually.
    Apr 20, 2015 @ 19:02
    Robert J. Bullock
    Actually, it's 205 nodes... So I wrote a pure t-sql means of doing it... Not sure how to share this properly. First thing is create this function in your Umbraco database:
    CREATE FUNCTION [dbo].[mntpConvert] (@mntpXml ntext)
        RETURNS nvarchar(MAX)
    AS BEGIN
        -- Declare the return variable here
        DECLARE @Result nvarchar(MAX)
        DECLARE @list nvarchar(MAX)
        DECLARE @xml XML
        DECLARE @mntpData nvarchar(MAX)
        SELECT @mntpData = CONVERT(nvarchar(500),@mntpXml)
        SELECT @xml = CONVERT(xml, @mntpData)
        SELECT @list = ISNULL( @list + ',', '' ) + x.y.value('.', 'VARCHAR(500)' )
        FROM @xml.nodes('MultiNodePicker/nodeId') x(y)
        -- Add the T-SQL statements to compute the return value here
        SELECT @Result = CONVERT(nvarchar(MAX),@list)
        -- Return the result of the function
        RETURN @Result
    END
    Then you have to figure out how to query the cmsPropertyData and update the right records. I did it by finding my property's id and creating the appropriate update statement.
    Apr 20, 2015 @ 19:04
    Robert J. Bullock
    Here's my t-sql statement to do the above but OBVIOUSLY you'd want to change the propertyTypeId:
    UPDATE cmsPropertyData
    SET dataNvarchar = dbo.mntpConvert(dataNtext)
    WHERE (propertytypeid = 138)
    AND (DATALENGTH(dataNtext) <> 0)
    AND (dataNtext IS NOT NULL)
    Apr 20, 2015 @ 19:06
    Robert J. Bullock
    And for good measure, set the dataNtext column to null:
    SET dataNText = NULL
    Apr 20, 2015 @ 22:48
    Robert J. Bullock
    Here's the code formatted better...
        -- Add the parameters for the function here
        @mntpXml ntext
    AS
    BEGIN
        DECLARE @xml XML
        RETURN @Result
    END
    GO
