I faced a weird issue that when I go on Developer section it gives me below error.
I have checked Umbraco Trace Log. It generates below error.
ERROR Umbraco.Core.UmbracoApplicationBase - [Thread 13] An unhandled exception occurred
System.InvalidOperationException: An error occurred when trying to create a controller of type 'Umbraco.Web.Mvc.RenderMvcController'. Make sure that the controller has a parameterless public constructor. ---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ArgumentNullException: Value cannot be null.
Parameter name: umbracoContext
at Umbraco.Web.Mvc.UmbracoController..ctor(UmbracoContext umbracoContext)
at Umbraco.Web.Mvc.UmbracoController..ctor()
at Umbraco.Web.Mvc.RenderMvcController..ctor()
--- End of inner exception stack trace ---
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at System.Activator.CreateInstance(Type type)
at System.Web.Mvc.DefaultControllerFactory.DefaultControllerActivator.Create(RequestContext requestContext, Type controllerType)
at System.Web.Mvc.DefaultControllerFactory.GetControllerInstance(RequestContext requestContext, Type controllerType)
at Umbraco.Web.Mvc.UmbracoControllerFactory.OverridenDefaultControllerFactory.GetControllerInstance(RequestContext requestContext, Type controllerType)
at Umbraco.Web.Mvc.UmbracoControllerFactory.CreateController(RequestContext requestContext, String controllerName)
at Umbraco.Web.Mvc.RenderControllerFactory.CreateController(RequestContext requestContext, String controllerName)
at Umbraco.Web.Mvc.MasterControllerFactory.CreateController(RequestContext requestContext, String controllerName)
at System.Web.Mvc.MvcHandler.ProcessRequestInit(HttpContextBase httpContext, IController& controller, IControllerFactory& factory)
at System.Web.Mvc.MvcHandler.BeginProcessRequest(HttpContextBase httpContext, AsyncCallback callback, Object state)
at System.Web.Mvc.MvcHandler.BeginProcessRequest(HttpContext httpContext, AsyncCallback callback, Object state)
at System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.BeginProcessRequest(HttpContext context, AsyncCallback cb, Object extraData)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
2015-04-29 14:59:31,186 [66] INFO Umbraco.Web.Security.WebSecurity - [Thread 40] User Id: 0 logged in
2015-04-29 14:59:31,263 [66] INFO Umbraco.Core.PluginManager - [Thread 13] Starting resolution types of Umbraco.Web.Trees.TreeController
2015-04-29 14:59:31,263 [66] INFO Umbraco.Core.PluginManager - [Thread 13] Completed resolution of types of Umbraco.Web.Trees.TreeController, found 4 (took 0ms)
Has it been acting like that all along or did it just started to happen? Is it happening locally or on a server? Do you see any error messages in the browsers console log as well?
Issue in developer section Umbraco 7.2.4
I am using Umbraco 7.2.4 version.
Can any one help?
Thanks in advance.
Regards,
Urvish Mandaliya
Hi Urvish
Hi Jan,
Thanks for the reply.
I am currently working in the local environment. This error occurred in this env.
UmbracoTraceLog I have pasted above. And yes I get error log in browser console. Please see below screenshot of that.
Its just started to happen now. Actually when I go to developer section for creating a data type I found that issue.
And I have downloaded Umbraco cms from nuget package.
Regards,
Urvish Mandaliya
I found the solution.
I have removed filed of ExamineIndex from the below path inside Umbraco directory structure.
~\App_Data\TEMP\ExamineIndexes
And yupeeee it works.
Regards,
Urvish Mandaliya
