  • Dhiren 60 posts 202 karma points
    May 22, 2015 @ 11:23
    Dhiren
    Scheduler not working in Load Balancing environment
    I have set one page to run as interval of 120 min. I have set its physical URL like : http://www.test.com/umbraco/Dialogs/Custom/CustomPublish1.aspx
    Now, when scheduler is trying to run schedule, it is giving below error in log file.
    ERROR umbraco.presentation.publishingService - [Thread 34] Error sending url request for scheduled task
    System.Net.WebException: The remote server returned an error: (404) Not Found.
       at System.Net.HttpWebRequest.GetResponse()
       at umbraco.presentation.publishingService.GetTaskByHttp(String url)
    Now, when i try to browse my URL, it is properly working without error. What can be issue?
    Dhiren
    May 22, 2015 @ 11:59
    Dave Woestenborghs
    Can you post your scheduler config?
    And also is the page available on the url you configured. Does it run when you call it your self from the browser ?
    Dave
    May 22, 2015 @ 12:33
    Dhiren
    Yes it runs when i call it from browser.
    umbracoSettings.config file
    <scheduledTasks>
        <!-- add tasks that should be called with an interval (seconds) -->
       <task log="true" alias="scheduleUpdateTask" interval="300" url="http://dev-project/umbraco/Dialogs/Custom/CustomPublish1.aspx"/>
     </scheduledTasks>
    Dhiren
    May 22, 2015 @ 13:03
    Dave Woestenborghs
    Config seems okay to me. Maybe the problem is in your code.
    Can you place a debug breakpoint to see if it get's hit by the scheduler.
    Dave
    May 28, 2015 @ 07:41
    Dhiren
    After many trials, i solved issue by calling my URL using ip address instead of domain. I don't know why it happens but it resolves my issue when i use IP Address instead of domain.
    Dhiren
