sorry for the inconvenience, but Ihave another question ;
there is anotherproblemwith the administrationof my sitewhenI typed: mysite/umbraco,anerror messageappeared
Line 3: @using Umbraco.Core Line 4: @using ClientDependency.Core Line 5: @using ClientDependency.Core.Mvc Line 6: @using Umbraco.Core.IO Line 7: @using Umbraco.Web
ah ok, I think you should get a fresh download of umbraco for the version you have from here and then copy both ClientDependency dll's from the download to your bin folder.
Could not load ClientDependency.Core
hello everyone ,
I installed nuPickers on umbraco , after that I uninstalled it because I have not used it , but a problem appear on my website :
Could not load file or assembly 'ClientDependency.Core' or one of its dependencies. The system cannot find the file specified.
plz i need a help
thanks
Hi there,
I would suggest you download the dll from here, unzip it and copy it to your bin folder.
Jeavon
hi jeavon
Thank you veryyyyyyyyyyyy much, it is ok now :)
hi jeavon
sorry for the inconvenience, but I have another question ;
there is another problem with the administration of my site when I typed : mysite/umbraco, an error message appeared
ah ok, try to edit /config/clientdependency.config and increase the version number.
these are the version number that I have in my /config/clientdependency.config file :
and
<clientDependency version="1031273659" fileDependencyExtensions=".js,.css" loggerType="Umbraco.Web.UI.CdfLogger, umbraco">
which one that i need to change, and with what I'll change it ,
im realy sorry for the inconvenience
thanks
Thank you veryyyyyyyyyyyy much :)
