  • Son Pham 31 posts 72 karma points
    Jun 02, 2015 @ 10:39
    Son Pham
    LocalizationService.SavedDictionaryItem event does not fire
    Is it a bug in Umbraco 7 ? I can catch media service event when I click save button. But does not work for localization service ? Is there any way to catch event when user save or delete dictionary item.
    Thank you so much
    public class RegisterEvents : ApplicationEventHandler
        public RegisterEvents()
            MediaService.Saved += new TypedEventHandler>(MediaServiceSaved);
            LocalizationService.SavedDictionaryItem += new TypedEventHandler>(DictionaryServiceSaved);
        void MediaServiceSaved(IMediaService sender, SaveEventArgs e)
            foreach (var mediaItem in e.SavedEntities)
                // Do whatever you want with each entity
        void DictionaryServiceSaved(ILocalizationService sender, SaveEventArgs e)
            foreach (var dicItem in e.SavedEntities)
    Jun 02, 2015 @ 13:08
    Alex Skrypnyk
    Hi Son,
    Where are you registering your events ?
    Did you read https://our.umbraco.org/Documentation/Reference/Events-v6/Application-Startup ?
    Jun 02, 2015 @ 13:14
    Son Pham
    Hi Alex. I register by creating cs class inherit ApplicationEventHandler. The problem is if you see in my code snippet MediaService work but LocalizationService does not work. I dont know why. I also try to put event register in ApplicationStarted instead of default contructor but does not help
    protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
    Jun 15, 2015 @ 19:38
    Son Pham
    Has anybody the same problem with me. Some event of umbraco 7 does not work
  • Yakov Lebski 594 posts 2350 karma points
    Jul 05, 2015 @ 12:49
    Yakov Lebski
    I have the same problem in 7.2.6
    Jul 10, 2015 @ 07:40
    Yakov Lebski
    please vote this issues http://issues.umbraco.org/issue/U4-4137
