Hi. I am working on a Umbraco 7 website. I am using a CE database at the website (remote) but I was stupid enough to overwrite the web.config file with my local web.config without having a backup.
Now does someone know where I can replace code in order to make a connection to my remote database. On my local edition I have a connection to an SQL Server Management database. Below I put the part of the web.config file that I think is the part that I will have to change.
Any help highly appreciated since it could most probally save me for a couple of hours of working :-).
// Lars
<connectionStrings> <remove name="umbracoDbDSN" /> <add name="umbracoDbDSN" connectionString="Server=localhost;Database=Salsabonito2015;Integrated Security=true" providerName="System.Data.SqlClient" /> <!-- Important: If you're upgrading Umbraco, do not clear the connection string / provider name during your web.config merge. --> </connectionStrings> <system.data> <DbProviderFactories> <remove invariant="System.Data.SqlServerCe.4.0" /> <add name="Microsoft SQL Server Compact Data Provider 4.0" invariant="System.Data.SqlServerCe.4.0" description=".NET Framework Data Provider for Microsoft SQL Server Compact" type="System.Data.SqlServerCe.SqlCeProviderFactory, System.Data.SqlServerCe" /> <remove invariant="MySql.Data.MySqlClient" /> <add name="MySQL Data Provider" invariant="MySql.Data.MySqlClient" description=".Net Framework Data Provider for MySQL" type="MySql.Data.MySqlClient.MySqlClientFactory, MySql.Data" /> </DbProviderFactories> </system.data>
Lost remote connection string to a CE database
// Lars
Problem sloved, I replaced the connectionString like below
<remove name="umbracoDbDSN" /><!-- <add name="umbracoDbDSN" connectionString="Server=localhost;Database=Salsabonito2015;Integrated Security=true" providerName="System.Data.SqlClient" />-->
<add name="umbracoDbDSN" connectionString="Data Source=|DataDirectory|\Umbraco.sdf;Flush Interval=1;" providerName="System.Data.SqlServerCe.4.0" />
