  • Son Pham 31 posts 72 karma points
    Jun 12, 2015 @ 09:24
    Son Pham
    Some events does not fire
    I have implemented to listen to event. But some of them does not work. The code worked correctly with Saved and MenuRendering event but does not work with Deleted and also Deleting. I am using version 7.2.2. Do I miss something ? Thanks
    public class RegisterEvents : ApplicationEventHandler
        protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
            ContentService.Saved += ContentService_Saved;
            ContentService.Deleted += ContentService_Deleted;
            TreeControllerBase.MenuRendering += TreeControllerBase_MenuRendering;
  • Maff 141 posts 466 karma points
    Jun 15, 2015 @ 10:19
    Maff
    Hi Son,
    Your overrides are processed when the Umbraco application starts so unless you've restarted your application (by recycling the App Pool) then these intercepts won't fire.
    Maff
    Jun 15, 2015 @ 19:35
    Son Pham
    Hi Maff Thank you for your reply. I am testing from localhost visual studio. Everytime I try to debug with F5 then I think the application has been recycled so the events should work fine but in reality it does not. I tried with F5 and create some stuff and save. SAVED event raise. Right click on my content. MenuRendering event raise. But Right click and delete item. DELETED event does not fire. That's weird
    Jun 15, 2015 @ 21:21
    Maff
    When you right click > delete an item, you're not actually deleting it but moving it to the Recycle Bin. So try overriding the TRASHED event rather than the DELETED event.
    See here for a full list of the Content Service events and an explanation of when they fire.
    Maff
