I have faced with some strange problem during the installation that I currently unable to solve.
I use Visual Studio 2013.
Empty project was created
Umbraco (7.2.6) was added to the solution using NuGet
Ctrl+F5 started the project.
I had an installation script started and finished without errors. Though, the "Installation is complete!, get ready to be redirected to your new CMS." is the last message Umbraco displays. Now I can wait for ages for this redirection and it won't happen.
What I tried to do:
a) Took a look to the logs. The last string was "2015-06-20 19:07:19,746 [22] INFO Umbraco.Web.Search.ExamineEvents - [T18/D11] Initializing Examine and binding to business logic events" . There were some minor exceptions before, but I have seen them on working environment also.
b) Tried to re-install IIS 8 - didn't solve the problem
c) I've tried the similar installation on IIS 8.5 (not Express) - on that server everything works perfect
d) Took a look to the system events. Journal says IIS 8 warning message, that the static compression was disabled. That's all, nothing more.
If I restart Visual Studio it seems that the installation process is complete and I can use admin side.
But why this problem during the installation occurs? Have someone seen something like this? I used to install Umbraco before (7.1*) but have not seen such behaviour before.
IIS 8 Express - problem with Umbraco installation
What I tried to do:
a) Took a look to the logs. The last string was "2015-06-20 19:07:19,746 [22] INFO Umbraco.Web.Search.ExamineEvents - [T18/D11] Initializing Examine and binding to business logic events" . There were some minor exceptions before, but I have seen them on working environment also. b) Tried to re-install IIS 8 - didn't solve the problem c) I've tried the similar installation on IIS 8.5 (not Express) - on that server everything works perfect d) Took a look to the system events. Journal says IIS 8 warning message, that the static compression was disabled. That's all, nothing more.
Ok, what I see now this is the problem with Internet Explorer. Everything works fine with Opera.
My IE version is:
