  • Sebastian Dammark 583 posts 1407 karma points
    Jun 23, 2015 @ 08:09
    Sebastian Dammark
    Unable to login, using 7.2.6 on SQL CE
    I've installed Umbraco latest version on SQL CE yesterday and everything went smoothly. Then my session timed out and I couldn't login again. First I thought that I've misspelled the password so I re-installed the bastard and everything was fine.
    Now, this morning, I can't login again, what the heck is going on here ? Am I totally losing it ?
    - Smokey, this is not 'Nam. This is bowling. There are rules.
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Jun 23, 2015 @ 08:13
    Dave Woestenborghs
    Hi Sebastian,
    Are you running on IIS Express. I self had some issues with changes not being persisted in SQL CE.
    There is also an issue about it : http://issues.umbraco.org/issue/U4-4621
    Dave
    Jun 23, 2015 @ 08:20
    Sebastian Dammark
    No, running on 2008 R2 with IIS 7, I guess.
    Jun 23, 2015 @ 08:59
    Dave Woestenborghs
    If you look at the issue the problem is definitely SQL CE. In some cases data is not written to the database.
    Jun 23, 2015 @ 09:06
    Sebastiaan Janssen
    101
    Two things to look at:
    1. Check your cookies and make sure that the UMB_UCONTEXT cookie doesn't have an experiation in the past (it should be 24 hour from when you logged in).
    2. If you got desperate and tried to log in loads of times, your account will be locked. You can see a message in the log about that. The default number of password attempts is set to 10 so after 10 tries your account will be locked. You'll need to go into the umbracoUser table and find your user, the column userNoConsole should be set to 0, if it is set to 1 then that means your account is locked.
    Jun 23, 2015 @ 10:16
    Sebastian Dammark
    It was the userNoConsole :)
    But I don't get why I got it in the first place, since I use a password manager.
    Now it's fixed.
