Hi everybody
Is it possible to make linebreaks when using the "textarea" type in macros?
I have tried with <br> and pressing enter, but it seems to just override it and renders out the text without linebreaks.
<br>
// René
Hi René
When you say textarea in a macro did you then mean the multiple textbook.
If so the you can output the content of the field containing HTML like this
@Html.Raw(CurrentPage.PropertyAlias)
And I think remember to write the linebreaks like
Hope this helps.
/Dennis
Hi Dennis
There is no "Multiple Textbox" in the macro parameters, I can only choose "textbox or textarea".
This is the macro code where there should be linebreaks in:
@Model.MacroParameters["text"]
Is it possible to use "Html.Raw" with my code?
Yes you can use the @Html.Raw in the macroParameters.
I have made a code snippet for you.
@inherits Umbraco.Web.Macros.PartialViewMacroPage @{ var macroText = Model.MacroParameters["text"]; } @if (macroText != null) { @Html.Raw(macroText) }
Hope this helps,
Your solution works perfectly in the Richtext editor but not with Grids.
Do you have any idea why?
Hi René,
I am not sure that this is possible in the Grid layout, so perhaps you should make a feature request about this http://issues.umbraco.org/issues/U4
Maybe you could consider to make a normal field outside the grid layout using the data type multiple textbox.
Then you can use this code.
@if (CurrentPage.HasValue("propertyAlias")) { @Html.Raw(CurrntPage.propertyAlias) }
Or as you already know then you can use it with a macro parameter outside the grid layout.
Linebreaks when using Macro "textarea" type
Hi everybody
I have tried with
<br>and pressing enter, but it seems to just override it and renders out the text without linebreaks.// René
Hi René
Hope this helps.
/Dennis
Hi Dennis
// René
Hi René
Hope this helps,
/Dennis
Hi Dennis
// René
Hi René,
/Dennis
