Examine index not Working for some Third level DocTypes
Hi Umbraco Team,
I had a requirement to create Multiple custom index for the Umbraco Project .
I found that one indexing was Working Perfectly Fine and other one was Not working . While searching for the issue i found that First Level and Second Level Doc-types are getting indexed and if Third Level Doc-type is used it was Not getting indexed.
Hi Umbraco Team,
Is any one Having some Quick Fix ?
Hi Every one I found a Temporary solution,
I had added the First Level Doctype ( Site Node ) and re-indexed it then its Working .
While searching the data filter with the Doctype Alias
issue exist with Umbtaco 7.2.5
