  • khansaa111 25 posts 55 karma points
    Jul 10, 2015 @ 11:22
    khansaa111
    comment in umbraco
    I need to add the comment function under my Articles or posts in umbraco , so i do everything to get the result , " the creation of document type called Comment with a textstring property called commentName and a textbox multiple property called commentMessage " also I authorized the Comment document type as child document type to mu textpage document type .
    and the creation of this script in the scripting file , after that i added it below the bodyText in my template.
    but
    but an error message appears "Error loading MacroEngine script (file: Comment.cshtml) "
    I dont knew why ?
    this is the script
    @using umbraco.cms.businesslogic.web
    @* Some global variables *@
    @{ var successfulPost = false; var name = Request["name"]; var message = Request["message"]; }
    @* Handle form post: create a new document if a valid post*@
    @if (IsPost) { if (name!="" && message !="") { var dt = DocumentType.GetByAlias("Comment");
    @* Make sure its a valid document type alias *@
    if (dt != null)
      var author = umbraco.BusinessLogic.User.GetUser(0);
      var doc = Document.MakeNew("Comment", dt, author, Model.Id);
      doc.getProperty("commentName").Value = name;
      doc.getProperty("commentMessage").Value = message;
      @* Tell umbraco to publish the document *@
      doc.Publish(author);
      umbraco.library.UpdateDocumentCache(doc.Id);
      successfulPost = true;
    @* Render the Html *@
    @if (successfulPost) {
    Successful post
    Thank you @name for your message:
    @message
    Comments:
    @foreach (dynamic c in Model.Comment) {
    @c.commentMessage
    By : @c.commentName (at @c.CreateDate)
    Add a new comment:
    Jul 10, 2015 @ 12:00
    Ismail Mayat
    In umbracoSettings.config change line
    <MacroErrors>inline</MacroErrors>
    to
    <MacroErrors>throw</MacroErrors>
    That will give you error screen with more detailed information should to debug. Also as you are using v7 how come you are not using ContentService to create the comment, Document.MakeNew is being deprecated see https://our.umbraco.org/documentation/Reference/Management-v6/Services/ContentService
    Regards
    Ismail
    Jul 10, 2015 @ 12:20
    Dennis Aaen
    Hi khansaa111,
    Perhaps you should have a look on this package. https://our.umbraco.org/projects/website-utilities/ucommentsy
    Maybe it has the features that you are looking for.
    Hope this helps,
    /Dennis
