Hi guys,
Can you suggest the best way to force using https for login and authentication?
Alex,
Is this for backend or front end? I am assuming backend, see https://our.umbraco.org/forum/using/ui-questions/20866-Umbraco-backend-via-SSL
Hi Ismail,
Thanks for you answer, I meant not only admin part but for client area also. Member is authenticating on the site and begin to use SSL.
Take a look at https://our.umbraco.org/projects/website-utilities/https-redirect/
Wow Ismail, it's what I need, thank you very much.
Upload image
Best way to force https
Hi guys,
Alex,
Hi Ismail,
Alex,
