We have a live site and today an editor somehow managed to delete a container node containing hundreds of nodes. This container uses grid view. I restored the deleted node from recycle bin. I then tried to republish parent and children, it hung. So I restarted app pool then republished just the parent that all worked fine.
I then republished parent and all children, it published about 30 children then stopped no errors. I then went into grid and selected one item and tried to publish I get error cannot publish item parent not published however parent is definitely published.
Check for random orphaned versions. I had something similar to this a while go on v6. Also check the paths of the nodes in the DB. I think my issue was one of those two.......
In answer to my own question, as we are on azure i just restored db to yesterday 12 and now its all back up. I have manually emptied content recycle bin, the media wont empty its giving errors.
Parent not published issue
Anyone seen this before?
Regards
Ismail
I think I've seen this before where the DB still thinks a content item is in the recycle bin.
Try looking at the umbracoNode DB entry for the parent node and check that 'trashed' is set to 0.
Maff
Maff,
It is definitely not in the bin. Something else not quite right here, we are poking around in db at the moment.
Regards
Ismail
Regards
Ismail
