Hi all,
I have a problem when i hosting umbraco 7.1.2 on server (Win server 2008R2 IIS 7.5 dotnet frame work 4.5)
on local it's run normal, when put it on server some element not run with http protocol (exam: i click login link its no action so i cant go admin page)
i try with https protocol it't work fine.
I try google but i cant get any solution
Please help, Thanks.
hii jeffrey
I want to know why my website was not running login page when i used the http protocol , while https protocol is fine. Is my server problem? or need to configure something on iis.
Problem with hosting umbraco 7.1.2
Hi all, I have a problem when i hosting umbraco 7.1.2 on server (Win server 2008R2 IIS 7.5 dotnet frame work 4.5)
Is there any error message that you see?
What bindings are setup in IIS?
Do you only have an entry for Https?
hi john and ben, i cant see any error. My binding below
PS: my website run fine on local, but problem when i bring on server.
thanks!
What do you eventually try to accomplish?
Don't you want the whole site to run under https and just redirect the http-traffic to https?
What we normally do is:
Hope it helps,
Jeffrey
hii jeffrey I want to know why my website was not running login page when i used the http protocol , while https protocol is fine. Is my server problem? or need to configure something on iis.
Hi Tuan,
I don't know what the problem is :), but why do you want to run your loginpage with http? Isn't it enough to only run it with https
Greetings Jeffrey
