  • Raymond 2 posts 72 karma points
    Aug 08, 2015 @ 00:09
    Raymond
    SurfaceController not working with jquery ajax POST
    Hi.
    I am using Umbraco 7.2 and I am trying to update a div element using jquery ajax.
    Let me show you what I have so far.
    Through Umbraco CMS I have created a Template and some partial views.
    MyTemplate.cshtml...
        Layout = null;
    <head>
        <meta charset="utf-8" />
        <title>What</title>
        <script src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js"></script>
    </head>
    <body>
        @Html.Partial("~/Views/Partials/_FirstPartial.cshtml")
    </body>
    Views/Partials/_FirstPartial.cshtml...
    <h1>Hello Calendar</h1>
    <a id="hypUpdateContainerTwoSGM" href="javascript:void(0);">Update Container Two</a>
    <div id="divUpdateContainerTwo">This should change.</div>
        $("#hypUpdateContainerTwoSGM").click(function () {
            PostSurfaceDataSGM();
        function PostSurfaceDataSGM() {
            $.ajax({
                url: '/umbraco/Surface/TestSurface/GetMyBigCalendarMessage',
                async: false,
                type: "POST",
                data: JSON.stringify({ "locationId": 1 }),
                dataType: "html",
                contentType: "application/json",
                error: function (data) {
                    alert(data);
                success: function (data, textStatus, jqXHR) {
                    $("#divUpdateContainerTwo").html(data);
    </script>
    Controllers/TestSurfaceController.cs...
    using System;
    using System.Web;
    using System.Web.Mvc;
    using Umbraco.Web.Mvc;
    public class TestSurfaceController : SurfaceController
        [HttpPost]
        public ActionResult GetMyBigCalendarMessage(int id)
            return PartialView("~/Views/Partials/_ThirdPartial.cshtml", tvm);
    Sorry for the bad formatting. Thanks for your time.
  • Tom Van Rompaey 38 posts 136 karma points
    Aug 08, 2015 @ 09:22
    Tom Van Rompaey
    The JSON parameter in your Ajax call needs to have the same name as in your controller.
            $.ajax({
                async: false,
                type: "POST",
                data: JSON.stringify({ "id": 1 }),
                dataType: "html",
                    alert(data);
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Aug 09, 2015 @ 11:44
    Steve Morgan
    I've had issues trying to use a single Int as a variable in a POST - MVC seems to expect and only match methods on an object - use a model / simple object instead or change it to a GET and add the data to the URL you're posting.
    Stick a break point on your surface controller method to ensure it's routing it correctly.
  • René Pjengaard 118 posts 702 karma points c-trib
    Aug 10, 2015 @ 07:36
    René Pjengaard
    Hi Raymond,
    as Steve mention, you can´t use attributes like that on a post-method. Try take a look at this Gist to get the hang of how it is done: https://gist.github.com/rpjengaard/a80d369f1eff3a266faa
    Best regards
    René
