  • Alex 79 posts 416 karma points
    Aug 12, 2015 @ 10:40
    Alex
    length issue
    please tell me what limit of word of text string document type in umbraco admin side
    how to stop add text in document type field,
    only 100 word inserted in umbraco admin side
    Aug 12, 2015 @ 10:45
    Alex Skrypnyk
    Hi Max,
    Did you mean how many letters can you insert in the text field ?
    Thanks, Alex
    Aug 12, 2015 @ 10:46
    Alex
    hi
    yes alex
    thanks
    Aug 12, 2015 @ 10:52
    Alex Skrypnyk
    Umbraco doesn't support such functionality out from the box. So, Max, you can create your own datatype like that :
    http://www.markadrake.com/blog/2015/01/22/custom-umbraco-property-editor-tutorial-character-counts/
    It's great property editor and good practice for learning umbraco.
    Thanks, Alex
    Aug 12, 2015 @ 10:53
    Alex
    thanks alex
    Aug 12, 2015 @ 11:00
    Alex Skrypnyk
    Another way is to add validation pattern like that:
    http://screencast.com/t/DIqTexICpl3o
    Regex:
    ^.{0,20}$
    But I don't like that way because of editor doesn't know what the problem when trying to save data.
    Thanks, Alex
    Development company: http://ukad-group.com/
    Aug 12, 2015 @ 11:42
    Alex
    hi alex,
    this Regx doesn't work
    thanks
    Aug 12, 2015 @ 11:45
    Alex Skrypnyk
    It works ) I tested it before posting, you have to past it when creating new property in your document type.
    Aug 12, 2015 @ 12:03
    Alex
    i am created new property then put it to validation field but when edit in content page it not work.
    hope u understand thanksenter image description here
    Aug 12, 2015 @ 12:17
    Dennis Aaen
    Hi Max,
    If you have full access to the Umbraco TV, then you can follow this chapter about building property editors. In this case you will be guided to built a char limit property editor
    http://umbraco.tv/videos/umbraco-v7/developer/extending/property-editors/
    Else try to see this package https://our.umbraco.org/projects/backoffice-extensions/kraftvaerkmaxlength/
    Hope this helps,
    /Dennis
    Aug 12, 2015 @ 12:20
    Alex Skrypnyk
    Thanks, Dennis, Great package and this is third way to create length limitation for textbox )
    Thanks, Alex
  • Bjarne Fyrstenborg 1286 posts 4060 karma points MVP 8x c-trib
    Aug 12, 2015 @ 12:49
    Bjarne Fyrstenborg
    I think it only validates the regex when you submit the form - so when you save or publish the page.
    If you want to restrict the limit as the editor type into the field, you should use a custom property editor (datatype). You can use the one mentioned before or install this package https://our.umbraco.org/projects/backoffice-extensions/kraftvaerkmaxlength/
    /Bjarne
    Aug 12, 2015 @ 12:09
    Alex Skrypnyk
    It works when you insert text bigger then 20 symbols in that field.
    Aug 12, 2015 @ 12:51
    Alex
    how to install these package, am not install any package before
    pls help
    thanks
    Aug 12, 2015 @ 12:54
    Alex Skrypnyk
    1) Via Nuget - PM> Install-Package MaxlengthPropertyEditor
    2) Or download zip from here - https://our.umbraco.org/projects/backoffice-extensions/kraftvaerkmaxlength/ and go to the developers section in Umbraco, install package and select this zip
    3) Via Umbraco package repository, go to the admin, developers section, packages, Umbraco package repository and find what you need
    Thanks, Alex
    Aug 13, 2015 @ 10:47
    Alex
    hi alex,
    after install the package nothing working
    thanks
    Aug 13, 2015 @ 10:56
    Bjarne Fyrstenborg
    Hi Max
    Please provide some more details of what is not working. Do you get any errors? Which version of Umbraco do you use?
    Maybe post a screenshot of the what you see or what is broken.
    /Bjarne
    Aug 13, 2015 @ 11:02
    Alex
    hi,
    nothing is broken, use 7.2.8 version of umbraco, i am install char limit package in umbraco repository, how to use ??
    Aug 13, 2015 @ 11:08
    Bjarne Fyrstenborg
    Is it this Char Limit package you refer to? https://our.umbraco.org/projects/backoffice-extensions/char-limit/
    You can't use it for Umbraco 7..
    But you can use this package for Umbraco 7: https://our.umbraco.org/projects/backoffice-extensions/kraftvaerkmaxlength/
    After install you need to create a new datatype and choose the property editor from the dropdownlist. Then you go to you document type and choose the newly created datatype for your property.
    /Bjarne
    Aug 13, 2015 @ 11:09
    Dennis Aaen
    Hi Max,
    When you have installed the package into your Umbraco installation. Then you need to go to the developer section into the Data Types folder.
    Click create a new data type, give it a name, and then choose the MaxlengthPropertyEditor as the property editor.
    The you can add some settings to it. Save the new data type and then add on your document types where you need to use it.
    Hope this helps,
    /Dennis
    Aug 13, 2015 @ 11:47
    Alex
    thanks to all its working
  • Antoinette Silago 21 posts 92 karma points notactivated
    Jul 11, 2017 @ 17:57
    Antoinette Silago
    Hi All,
    Will this package work with Umbraco form fields?
