can someone explain the difference please:
Library.NodeById(1052); and Umbraco.Content(id) ?
Is there an advantage here?
Hi Damon,
Library.NodeById is obsolete (it was part of the first Umbraco Razor implementation called DynamicNode), you should always use methods from the Umbraco helper such as Umbraco.Content
Library.NodeById
Umbraco.Content
Jeavon
Also you can use Umbraco.TypedContent() at the frontEnd, in your razor views, it's much faster then Umbraco.Content().
Read more here: https://our.umbraco.org/documentation/Reference/Templating/Mvc/querying
Thanks, Alex
Whats the difference between using Library.NodeById(1052); and Umbraco.Content(id) ?
Hi Damon,
Library.NodeByIdis obsolete (it was part of the first Umbraco Razor implementation called DynamicNode), you should always use methods from the Umbraco helper such asUmbraco.ContentJeavon
Hi Damon,
Thanks, Alex
