I have read the documentation where is explained how to replace line breaks with html tag.
Inside a jquery script I use this code:
@{ foreach(var itemfinale in CurrentPage.Children) { if(itemfinale.HasValue("descrizioneCompleta")) { <text> @{ var multiLine = @itemfinale.descrizioneCompleta; } $(".sfondo-nero-opaco").append("@Umbraco.ReplaceLineBreaksForHtml(multiLine)"); </text> } } }
But I received this error:
The best overloaded method match for 'Umbraco.Web.UmbracoHelper.ReplaceLineBreaksForHtml(string)' has some invalid arguments
On line:
@Umbraco.ReplaceLineBreaksForHtml(multiLine);
Where am I wrong ?
Are you sure that @itemfinale.descrizioneCompleta returns a string?
You could try to print out a typeof or gettype at runtime on it..
If it is an object or something the error makes sense.
/Jesper
Hi Jesper :)
Yes, @itemfinale.descrizioneCompleta returns a string on two line. I saw it from the console...
Ok.
You could try to typecast to be sure:
multiLine.ToString()
or @Umbraco.ReplaceLineBreaksForHtml((string)multiLine)
Still it does not work
Upload image
Problem with replace line breaks
On line:
Where am I wrong ?
/Jesper
Hi Jesper :)
Ok.
/Jesper
