I have a partial called BottomNavigation.cshtml in my Views/Partials folder. I am trying the following:
$("#footer").load("../Views/Partials/BottomNavigation.cshtml");
But it says 404 not found. Is this possible? Currently, I am doing:
@{Html.RenderPartial("BottomNavigation.cshtml");} which does work.
Hi!
Is it a static file or does it need a model to render? This should work for static content:
public ActionResult GetPartial(string partialName){ return PartialView("~/Views/Partials/"+partialName); }
then
$("#footer").load("../MyController/GetPartial?partialName=BottomNavigation");
May I ask you what you are trying to achieve by loading it as ajax?
Load cshtml with jquery.load
@{Html.RenderPartial("BottomNavigation.cshtml");}which does work.Hi!
then
