Hi Guys,
I am wondering if its possible to use viewport with umbraco razor codes?
For example i wan to do something like this
@if(viewport < 768px) { //run razor codes here }
I am not sure if this is possible, so far i tried passing variable from a jquery script to razor variable. It won't work.
Does anyone know if this is possible?
Thanks in advance. Ralee
Hi Thomas Lee,
I think you are confusing 2 things.
Razor is executed on the server, and jQuery is executed in the browser (client-side).
This means you can't use client side (jQuery) variables in your razor script.
Maybe you can explain what you are trying to achieve so we can see if there is a different solution to your problem.
Dave
Hi Dave,
Thanks for the reply.
I have a Umbraco form I want to implement on two different part of the page depending on the viewport.
For mobile viewport i want to display it on the top of the page. For tablet viewport and above i want to display it on bottom.
The script looks like this @Umbraco.RenderMacro("FormsRenderForm", new {FormGuid="e17a2df0-c348-4495-83ac-c52e958c5862"})
So my plan is to do something like this
//top @if(viewport < 768){ @Umbraco.RenderMacro("FormsRenderForm", new {FormGuid="e17a2df0-c348-4495-83ac-c52e958c5862"})} //bottom @if(viewport < 768){ @Umbraco.RenderMacro("FormsRenderForm", new {FormGuid="e17a2df0-c348-4495-83ac-c52e958c5862"})}
Thanks for helping me!
Cheers Ralee
You can render the form twice and show/hide it using css media queries.
I never tried using the same form twice on a page using Umbraco Forms, but I can imagine that i can cause problems.
I tried doing that. But my second form Google Recaptcha won't work..
Maybe you can render the form once. And change the location using javascript ?
That's totally new to me.
Can you share a short snippet on how that works?
Thanks Ralee
Maybe this article can help you out : http://www.elated.com/articles/jquery-removing-replacing-moving-elements/
Using viewport with razor
Hi Guys,
@if(viewport < 768px) { //run razor codes here }I am not sure if this is possible, so far i tried passing variable from a jquery script to razor variable. It won't work.
Hi Thomas Lee,
Dave
Hi Dave,
Cheers Ralee
Dave
Hi Dave,
Dave
Thanks Ralee
