  • Nikolai 2 posts 72 karma points
    Sep 10, 2015 @ 06:23
    Nikolai
    RavenDB Problems When Installing UCommerce Package
    Hey!
    I installed umbraco 7.2.8 using nuget 3.0.6 on an empty ASP.NET application in VS15 with a localhost MS SQL Database.
    After umbraco was successfully installed i went ahead and installed the uCommerce package using the Umbraco repository, which again seemed to be successful.
    However now, when i try to save any kind of product in uCommerce i get the following warning, which effectively ends any kind of interaction with uCommerce products:
    System.ComponentModel.Composition Warning: 1 : The ComposablePartDefinition 'Raven.Database.Server.Security.OAuth.OAuthClientCredentialsTokenResponder' has been rejected. The composition remains unchanged. The changes were rejected because of the following error(s): The composition produced a single composition error. The root cause is provided below. Review the CompositionException.Errors property for more detailed information.
    1) No exports were found that match the constraint:
        ContractName    Raven.Database.Server.Security.OAuth.IAuthenticateClient
        RequiredTypeIdentity    Raven.Database.Server.Security.OAuth.IAuthenticateClient
    Resulting in: Cannot set import 'Raven.Database.Server.Security.OAuth.OAuthClientCredentialsTokenResponder.AuthenticateClient (ContractName="Raven.Database.Server.Security.OAuth.IAuthenticateClient")' on part 'Raven.Database.Server.Security.OAuth.OAuthClientCredentialsTokenResponder'.
    Element: Raven.Database.Server.Security.OAuth.OAuthClientCredentialsTokenResponder.AuthenticateClient (ContractName="Raven.Database.Server.Security.OAuth.IAuthenticateClient") -->  Raven.Database.Server.Security.OAuth.OAuthClientCredentialsTokenResponder -->  AssemblyCatalog (Assembly="Raven.Database, Version=2.5.0.0, Culture=neutral, PublicKeyToken=37f41c7f99471593")
    I am using ISSExpress, if that is of any relevance.
    Cheers.
    Sep 10, 2015 @ 06:27
    Sebastiaan Janssen
    You might have more luck asking for support on their own forums: http://eureka.ucommerce.net
    Sep 10, 2015 @ 06:28
    Nikolai
    Thank you for the quick reply!
    I will try there too then.
