  • Matthieu Nelmes 102 posts 385 karma points
    Sep 17, 2015 @ 12:09
    Matthieu Nelmes
    Setting Property Values Programmatically
    I have a DocType for a venue that contains address details.
    When a CMS user saves a new store, I want to take the entered postcode, geocode the information to a Lat/Lng and then save the results within a read-only property for the venue.
    My first question is, am I correct in thinking this can be achieved through a custom event handler that hooks into the Publish events such as:
     public class EventHandler : ApplicationEventHandler
        protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
            ContentService.Publishing += ContentService_Publishing;
        void ContentService_Publishing(IPublishingStrategy sender, PublishEventArgs<IContent> e)
            foreach (var content in e.PublishedEntities)
                if (content.ContentType.Alias == Constants.DocumentTypeAliases.VENUE)
                var venueInputPostcode = content.GetValue<string>("venuePostcode");
                GeoLocation venueGeoCodedLocation = GeoCoder.GetCoordinates(venueInputPostcode);
                content.SetValue("venueLat", venueGeoCodedLocation.Lat);
                content.SetValue("venueLng", venueGeoCodedLocation.Lng);
    My second question is, since the Lat/Lng values are read-only from an end users perspective, is there any way these can be hidden properties within Umbraco?
    Sep 17, 2015 @ 17:30
    Matthieu Nelmes
    101
    Whoa! Hold up.
    I found a potential solution. Instead of hooking into the ContentService.Publishing event I went for ContentService.Published. This way I have access to the NodeId so my solution was as follows:
    Note! This has the potential to create an infinite loop if you're not careful. Because I only want to set the value the first time the postcode is entered, I'm checking to see if the GeoCoded Lat has already been entered.
     public class RegisterEvents : ApplicationEventHandler
            ContentService.Published += ContentService_Publishing;
                    if (content.GetValue<string>("venueLat") == string.Empty)
                        var contentService = new Umbraco.Core.Services.ContentService();
                        var venueDoc = contentService.GetById(content.Id);
                        venueDoc.SetValue("venueLat", venueGeoCodedLocation.Lat.ToString());
                        venueDoc.SetValue("venueLng", venueGeoCodedLocation.Lng.ToString());
                        contentService.SaveAndPublishWithStatus(venueDoc);
