GetCropUrl in razor macro not working in production
When using the GetCropUrl in my razor macro, the images are perfectly cropped on my development environment but ones I deploy my website to production, the images don't get cropped anymore. I'm using Umbraco 7.2.8.
The cached images of the crops are saved in App_Data. Most likely you didn't deployed that, hence the crops won't be shown. Try to resave the media item, to resaved the cropped files and see if it works.
Hi Wing, thanks for you answer. It was a completely new deployment so everything was copied to the production website, the cached images included, so this could not be the problem. And the media item is cropped on the fly in razor and not in the content node.
I found the solution, the ImageProcessor module wasn't served because the shared hosting environment was not running in Integrated Pipeline. After changing the cropping worked perfectly fine.
This is the code I'm using in my macro:
And this is the result I'm getting on my machine in development:
But after publishing the website to production (shared hosting) I'm getting this as a result:
Does anybody has any clue what may cause this problem? Thanks!
Kind Regards, Gert.
Any other ideas? Thanks!
Kind Regards, Gert.
